hola…podrias pasarme el programa para meter los contactos csv del 1702
ea4hal@yahoo.com
My spanish is rubbish but you want a csv file with ham contacts for the 1702? I’ve seen many people looking for them, but I’m not sure there actually is one? You will probably have to download one for another radio, and then edit it to match the 1702 format.
Been busy working on the AREDN Mesh Net project. Setting up a Supernode here in NW Florida. Now I have time to get back to the radio. I downloaded the files you sent me links to. Next thing is what to use to hook to the radio and how to get the correct program loaded into it where it will do something. I feel the radio can be saved and put to use. Please let me know. You can contact me at KV4ATV@gmail.com so we can work on this if you’d like. Wolfgang
Hello all
who doesn’t have a faulty 1702
I really need it for spare parts
if you don’t mind giving it to me
Better buy a new one or another brand
I will be glad to have any spare parts
I’m sorry, I don’t have spare parts available. Baofenga 1701 (2 pcs.) still works, although I do not use it. For the main wearable radio, I chose Anytone 878UV v. 2. Stationary yaesu ft-991a
Daniil,
Which files will restore it and I have to find a program that will connect and talk to the radio before I can flash new software into it. Any suggestions?
Wolfgang KV4ATV
я помогу восстановить тебе его
напиши мне
на воцап
Hola estimados, soy LU3DGP Germán desde Argentina.
Ya estoy perdido en todo el hilo. Por favor, alguien podrá ayudarme?
En mi Baofeng DM 1702 cuando lo de dejo para que se vean las Frecuencias, me permite pasar a VFO, pero cuando lo pongo en Canal no. Alguien me sabe decir cómo se puede hacer o qué versión se puede usar para que me deje pasar a VFO estando agendado como canal/nombre/alias?
Gracias por su ayuda
Saludos
LU3DGP
Hello dears, I am LU3DGP Germán from Argentina.
I’m already lost in the whole thread. Please, can someone help me?
On my Baofeng DM 1702, when I leave it to show the Frequencies, it allows me to go to VFO, but when I put it in Channel it doesn’t. Can anyone tell me how it can be done or what version can be used to let me go to VFO while being programmed as channel/name/alias?
thanks for your help
Greetings
LU3DGP
I bought two DM-X a few years ago, I always used it quite simply. But I would like to put a very precise frequency list, and so as I see it is quite complex with this model (why make so many variants ■■■■ it…) in short, my firmware version is: L05.01.004 (I tried with CHIRP, of course no Baofeng reference in the list works), I also tried (the CPS.exe, but does not work either)
Could you help me?
thanks in advance
J’ai acheté il y a quelques années deux DM-X, je l’ai toujours utilisé assez simplement. Mais j’aimerais mettre une liste de fréquence bien précise, et donc comme je vois c’est assez complexe avec ce modèle (pourquoi faire autant de variantes bordel…) bref, ma version du firmware est le : L05.01.004 (j’ai essayé avec CHIRP, biensur aucune référence Baofeng dans la liste fonctionne), j’ai aussi essayé (le CPS.exe, mais ne fonctionne pas non plus)
Pourriez vous m’aider ?
d’avance merci
Yes I would love to have it, if you don’t mind?
