Hi
Any one know if the yeasu ft60 radio can scan frequency 145300 to 147999 and returnand start all over again start scan 145300 to 147999 frequceny.
can you show steps doing low and upper limit scan,from 145300 to 147999.
what button to set on the radio.
mrel
Get into VFO mode. Enter lower frequency limit 145.300. Hold F/W for 1 second. Rotate dial to Select Channel Number L01. Press F/W.
Enter upper frequency limit 148.000. Hold F/W for 1 second. Rotate dial to Select Channel Number U01. Press F/W.
If the manual is confusing, there are lots of web sites that will detail scanning with an FT60.
Chicken hawk after following step you post what other keys need press to make the radio scan.mrel
