Hello:
New to the forum - looks like a good place to learn more about GMRS radios.
I’d like to know if anyone has a Wouxun KG-905G GMRS battery charger & would answer a couple of questions:
Does the charger consist of a cradle with a detached power source that plugs into 120v AC?
If so, could you tell me the output of the detached power source or the input of the cradle?
I’m trying to decide on a handheld GMRS for our expedition truck and I prefer being able to charge components without using our inverter. If the cradle is DC then I may be able to power the cradle directly from our 12 volt house battery bank with an adjustment of voltage (or if the cradle takes 12 volt DC without a voltage adjustment). If the cradle is AC then I’d be stuck with using our inverter.
Thanks in advance,
Howard
