Wouxun 935g plus help!
Using wouxun 935g plus radios in field hunting. Two users with radios, each using earpieces. Channel mode (channel 16). One radio is constantly saying “7….7…….” Driving me nuts. Amy ideas?
(Screen also blank upon turning on now, though I do get the prompts saying “channel mode, 16”)
My guess is that the “7” button on the extreme lower left corner of your keypad, is bumping into clothing or gear on your person, or perhaps into another object, such as a car seat, tree limbs, etc. To remedy this problem, hit the “Menu” key on your radio and then “2” and “9”.
This should put you in the “Voice” part of the menu. Press “Menu” a second time and you will see “ON”. Press the up or down arrow key on your keypad and it should show “OFF”. Press “Menu” again and then “Exit”. The voice should stop sounding whenever the “7” key gets bumped. Hope this helps!
