Hi all, I’m running into an issue installing the CE programming software for a Vertex Standard VX-160 (CE44) that I’m hoping someone has seen / has a solution to.
I got the programming software directly from Vertex Standards business site and after installing it on a Windows 7 64bit machine cannot seem to find an exe to run. I have the configuration files, and code plug files but no actually executable. I tried searching my PC without any luck. I have installed the software for programming the VX-400 and VX-350 series radios without any issue and looking in the directory for those I can see the executable with the other files.
Now, if I go to the control panel I can see it in the list of installed programs but can’t seem to run it. I’ve also tried running directly from the run window (CE44Win.exe) with no luck. I tried the download again to make sure it wasn’t corrupted and got the same results. I’ve also tried it on a Windows 8.1 PC and it did the same thing.
Has anyone else seen this? Or does anyone know where I can download just the EXE and not the installer?
Thanks in advance!
