The best way to tell is to charge them up and use them for a day. If you can transmit in several ten to twenty second intervals without a significant loss of power or battery drain, they are probably fine. However, if the battery level drops considerably after one or two short transmissions or if the power cuts out completely, then it is time to replace the battery.
