I have set offset on my KG 9uvd Mate when the 2 meter band is set as main, I cant seem to figure out how to set it for the 70 cm band, seem if i set it for the 70 cm band it will replace the 2 meter offset, i dont see a way to add the two different bands
I just got a KG-UV8H and have learned that I can set a different offset and offset direction (as well as other settings) on the A side vs the B side. Does your KG 9uvd allow for that?
I can do it on A side but not sure if it changes the B side
Make the B side active and change the offset to something different than you had previously set on the A side. Then switch back to the A side and see if the setting there is what you had previously set on A or if it’s what you just set on B. If it’s like my KG-UV8H, it will be different.
