Hi all, i am new to this game. My question is this… i have a scan king RX antenna and a Baofeng UV - 5RH. The antenna has a PL259 plug so what would i need either end of my coax cable for it to work?
Thanks in advance,
Paul
[email protected]
You want an SO239 (socket version for the 259 male) with a short length of flexible 50Ohm cable with an SMA on it - they’re quite common. The antenna cable is a bit too stiff for you to use just a 239 to sma solid adaptor, the radio constantly falls over.
Wouldn’t it be an SMA-F connector… Most if all Baofengs have an SMA-M on them.
Yes. Female on the antenna connection male on the radios. Forgot the ■■■!! This forum does not allow the s e x word! How quaint
You may want to try using the word gender. That is a common term for connectors. The other word is used extensively by spammers, which is why it is censored.
Got you! Trouble is us Brits rarely change unless forced - although male to female converters are often called ‘gender benders’ here - but I guess that needs to stop too! The youngsters of course want everything changing. Far too old for that!
