I just bought a new KG-UVD1P ht and it seems to be a good little rig for the money. I have a couple of questions.
Am I overlooking something or is there no way to toggle back and forth from memory mode (what I programmed into the ht) to VFO mode? I can’t seem the find the keystrokes to do that using the manual.
Might there be better programming software for this ht? What came with it in a word, stinks.
When the HT is put into “SCAN” the displays backlight and the keyboard light never time out, always on. It does shut off if the squelch is opened and locks on a busy channel.
I thought that is about the dumbest thing I’ve ever seen. Drain the battery faster while in scan, dah.
The only way I seen to keep the battery from draining faster while in scan was to shut the backlight off but then you must turn it back on again to see the display better later. Again, dumb.
Is there a setting I missed to have the backlight time out no matter what mode you put the radio in?
I’m also having trouble & in need of some advice. I can not seem to be able to get the USB driver to work. I run Windows 7 on my computer. I have downloaded from Wouxun’s web site & also from the disc that came with the USB cable many times. I’ve tried resetting the comport. Nothing seems to work. Has anyone had the same trouble & overcome it?
The drivers on the CD are useless. It is best to try the drivers in the files section of the above group. It took me a bit to get the right drivers set up too.
You can choose from available aisle of lip and eye products or create your own custom palette according to your desire.With online marketing gradually making an impact in the UK market, there is a sudden encroachment on this market by few scrupulous perfume retailers. mac makeup uk wholesale Available with exuberant range of makeup needs such as hair care, skin care, Face, Lips, Eyes everything.Amazingly enough, the scent of an essential oil can also tell your brain to trigger chemicals that relieve pain. Discount MAC Makeup They use these vehicles to sell all kinds of products.Points can usually be converted to cash and you can buy the products that you love at a few dollars off. buy MAC makeup online For Mac users, the equivalent of Arial is Helvetica.Keep your lids bare and then carefully draw either liquid or pencil liner along the upper lashline only, keeping the line fat and winging it out at the edges.
