I am looking for a 2-way for a motorcycle application. I want:
-a quality solution that will work well.
-VOX
-small and light enough to cary easily
-clear voice transmission
-noise/wind canceling mic
-possible future intigration with Autocom intercom system
-Would there be an advantage to the motorola CP series
So far my search seems to be pointing toward the XTN XV2100.
Is this a valid solution?
Does the HM200-MB1 headset work well with minimizing wind noise?
Are you aware of compatible VOX headsets that can be used in a helmet?
Can mike and speakers connect seperate or is it thu a single connector?
Do you price match or offer a volume discount for QTY(3)?
Will the stock frequencies be ok for non licenced use?
Thanks, Derrek
