Hi everyone!
I had a question for you guys:
firstly here is the headset I bought:
Two Way Radio Motorcycle Helmet Headset For KENWOOD
here are the walkies I have:
RADIO SHACK 21-1859 Ultra-Compact Personal Transceiver
http://support.radioshack.com/support_electronics/doc61/61431.pdf
I recently bought a motorcycle helmet headset for my two way radios that I had lying around the house. And I assumed they would work but they don’t fit in the holes…Now I opened up the back and tried to move the holes farther apart, which worked. And then inserted the headset into the holes and it fit perfectly! except I still couldn’t hear anything from the earphones and the other walkie wouldn’t transmit sound from the boom. Although, while plugged in, the walkie was constantly transmitting, except it would only transmit if sound went into the walkie mic and not the headset.
Is there anyway I can get this headset to work for this set of walkies? aka fiddling around with the circuits or something of that nature? Or am i better off returning these and giving up? thanks, hope you guys can help!
