Lost or misplaced my manual want to program new station with a PL any steps on programing and then useing a PL with it is what i,m looking for
See If This Helps
— Tone Code Table —
Code Freq.(Hz) Code Freq.(Hz) Code Freq.(Hz) Code Freq.(Hz)
01 67.0 16 114.8 31 192.8 46 1,700
02 71.9 17 118.8 32 203.5 47 1,750
03 74.4 18 123.0 33 210.7 48 1,800
04 77.0 19 127.3 34 218.1 49 1,300
05 79.7 20 131.8 35 225.7 50 2,000
06 82.5 21 136.5 36 233.6 51 2,200
07 85.4 22 141.3 37 241.8 52 2,975
08 88.5 23 146.2 38 250.3 53 2,550
09 91.5 24 151.4 39 500 54 2,295
10 94.8 25 156.7 40 600 55 2,125
11 97.4 26 162.2 41 700 56 1,275
12 100.0 27 167.9 42 800 57 1,445
13 103.5 28 173.8 43 900
14 107.2 29 179.9 44 1,000
15 110.9 30 186.2 45 1,600
Note: When the unit is provided with an optional tone squelch unit, tone codes are
different from above and refer to the tone the squelch unit code table.
After a round of procedures for storing the receiving and transmitting frequencies and
tone code, the Memory Address Indicator flickers showing the next channel. By repeating
the same procedures as above, you can store receive frequencies, receive tones, as well as
transmit frequencies and transmit tones in the memory bank AD through A9 and memory
bank BO through B 9 for a total of 20 channels.
After the tone code is entered in the B9 memory channel, the unit is in the Up/Down
mode for setting tone, shift width, delay scan and frequency stop other than in the memory
channels.
- The receiving tone code will be indicated by entering tone code number.
Press the M MODE key and the TONE indicator will flicker.
Select any desired tone code by the UP/DOWN key and push the M MODE key
to complete the entry.
Note: This procedure is not required unless the unit is provided with the tone squelch unit. - By the transmit tone code number, the transmit tone code will be indicated. Pushing the M
MODE key to let the indicator flicker. Then, select tone code desired by the use of the
UP/DOWN key and push the M MODE key again to complete the entry.
