Greetings, and sorry in advance for the length…
A friend of mine is moving into a very middle-of-nowhere place, a large property out in the Vermont countryside with a lot of land, bordering a small lake, with trails for snowmobiles, ATVs, etc. Geography has a few rolling hills but nothing huge.
So I want to get them a few good FRS/GMRS radios as a gift. I’ve done my research, but sadly the product docs only get you so far, so I’m hoping those with hands on experience can point me in the right direction.
Here are my requirements:
MUST NOT COOK ITSELF if left in a charger for a long time. IE, the charge controller must detect that it’s done charging and shut off the power or switch to float charge mode. I suspect these radios will be left in the charging bay for weeks, perhaps months at a time. If that will destroy the battery thru overcharging, that’s no good. Ideally it would be okay if left powered on in the base, but that’s not a requirement.
Good transmit power (ideally at least 2 watts in hi power mode). Measuring two-way radio TX range in miles is beyond absurd and borderline dishonest, as I’m glad to see the people in charge of this site/store have figured out. My friend’s place has a few rolling hills, so in a few areas it’s not quite line of sight, thus the desire for better TX power.
It should be relatively durable. These radios will be used in the ‘great outdoors’, I expect them to be dropped in the dirt and snow numerous times. Splash resistance is a plus.
Ideally, NOAA Weather Alert. SAME isn’t important, I just want the alert so if they’re out on a trail they hear if something is going to happen.
Price range keeps it in the consumer end of things, ie <$100 for 2.
Some quick searching narrowed me down to a few choices:
Uniden GMR2872 not available in your store :(. Upside- JIS7 waterproof (submersible 1 meter for 30 mins, and it floats), downside- can’t find RF output spec anywhere. It claims to have a ‘powerboost’ button, but no spec is given for RF power.
Midland GXT1000 full 5 watts of TX power and JIS4 rated (splash resistant), not as good as JIS7 but still good.
Specs quote ‘28 extra channels’, where are they? Is it something in the 900MHz band or maybe the old 46/49MHz area like the old cordless phones, or am I totally missing something about the FCC’s FRS/GMRS allocation?
Motorola MR350
Upside- I’ve used Motorolas in the past, can charge on mini usb (IE from a midland basecamp unit in an emergency), and has an inbuilt flash light. Also has SAME alerts.
Downside- no quoted water/weather resistance, NO IDEA what the transmit power is.
I’d also planned to get them a midland basecamp radio. However, will this radio cook its NiMH pack if left plugged in indefinitely? While the radios might be rarely used, the basecamp would probably never be unplugged except for a power outage or camping trip…
I’m hoping that some who have some hands on experience with the above units can give some feedback, mainly in how they react to being left in their chargers for long periods. Any other information / recommendations or other radios I should check out would be most welcomed…
Thanks in advance.
