motorola xv2600
I just purchased A xtn series xv2600 radio (used). It is supposed to be a 2 watt 6 channel unit. I can only display channels 1 & 2. I have progamed channel 1. I will prob never need more channels but would like to know they are there if I need them. What gives? The label on the back says it’s a xv2600, so I believe it is. Larry
I believe that there is a way, though programming mode, to disable channels on the XV2600 and XU2600. If you just bought the radios, start with a factory reset and that should get you back to the default settings. You can reset the radio by holding down the PTT and MENU buttons for 3 seconds while turning the radio on.
