Motorola Talkabout MH370CR Quits
Hi again:
One of our recently-purchased Motorola Talkabout MH370CRs seems to have quit transmitting and receiving.
I have scoured the settings, read the manual, closely compared with the other two radios which do work and can’t find the bug. Of course I have channel numbers and filtering set exactly as the others, but the beastie can’t seen to receive or transmit. There is a button to press which notifies another nearby radios with a ring tone, but nothing happens. Yes Ring Tones are on, etc. Weatheradio works OK.
Are these things that poorly built that they quit so soon? Anyone know how to go back to “factory default” and start over again ??
(although having been back and forth through the settings many times trying to fix this, I understand most of them, except maybe ivox and vox)
Help appreciated as we are leaving on a cruise shortly.
Thanks
If you purchased the radios from us, give us a call (1-800-584-1445). Most GMRS radios are rather reliable, you might need to contact Motorola to see if they are covered by the manufacturer’s warrantee:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=1a7469a62dce0210VgnVCM1000008806b00aRCRD
