Hello,
I need advice. I understand that both Motorola T8500R and Cobra LI6550 is not high-end radios. But, which is better? What I need is distance in urban area. Or, may be, you can advise about better choice ?
Thanks.
Hello,
Thanks.
If distance is your primary concern, I would recommend the Motorola T8500R if choosing between those two radios. The Cobra LI6000 series is designed with size and weight as the most important considerations, not range.
