Hi, I have some Motorola TLKR T80 Extreme two-way radios. Is there a way I can use them or one of them with another network using other brands of radio?
Can the set ‘scan’ while another device is transmitting and pick up its frequency and match to something in the range of channels and sub-channels within the T80. I hope I have expressed myself clearly!
Thanks if anyone can help or has done this.
That particular radio is designed for use on the PMR channels used in Europe and countries that have allocated 446mhz frequencies for non licensed use. In the US we have something similar, FRS that operates using 462/467mhz frequencies. Depending on where you are located, yes you could use those radios to communicate with other PMR radios. They will only work with other PMR radios and are not able to be programmed to operate out of the PMR frequency limits.
Hi, thanks for this. I believe I would be trying to connect with other radios using UK unlicensed PMR channels and frequency range. Just how to do it? The instructions in the user manual are vague! I guess I should ask one of the other (not Motorola TLKR T80) sets to transmit, say counting one to ten as I press the scan button on my set? If it detects the transmission and frequency how can I save it or match it to a channel number and sub channel within the T80? That is my question and have you ever used one? Cheers
The UK PMR446 band has become a sort of home for people to chat like CB with strangers - and the UK OFCOM authority seems happy. The snag is simple - the actual frequencies are allocated by OFCOM and everyone who sells the legal radios - the ones with low power and fixed antennas standardise on 16 basic frequencies - which your radio should have, or if it’s older, it could be the first 8. BUT - and it is a big but, there is no requirement for the radios to use the same CTSCC tones. The official idea is you talk to people you know, or work with, probably using identical radios. The ‘cb’ style craze at the moment is focussed around radios a bit more powerful and very importantly, programmable. These let you add transmit tones at will, and be able to switch off receive tones, so you can hear everyone, and then if that person is using a tone, you tell your radio to send that tone back - and you can talk to strangers. This is NOT what the basic radios are capable of doing - not the same design criteria. Baofengs with keypad programming are by far the most popular - the UV5 versions being very agile and hence handy. Your idea to transmit on one and receive on a programmable type will work. Look up the 16 channels, and set the smallest tuning step, as the UK ones are ofset a bit from the usual professional radio ones. On a radio woth tones OFF - tune the frequency band till you find it - and it matches the OFCOM list - google will find that. PMR446 frequencies, will do the trick. Unless your receive radio is clever, you will then have to engage CTCSS and try every frequency till you find the right one. Program this into a memory in the clever radio, then repeat for every channel. Tones vary as frequency changes in most radios. A real pain, but simple enough. Then - if you have the real PMR446 radio channels aligned with the clever radio’s memories - channel 2 is 2 and 3 is 3 and so on.
