Hello,
New to this, have some questions.
All Radios Motorola
6- XU2600 XTN
2- RDU4100 RDX
1- RDV5100 RDX ( I know this will never work with other radios, this will be separate question)
I would like channels 1&2 on all UHF radios to be the same, for private, in house use (campus)
Could/should the remaining channels be programmed for Public/Emergency frequencies in case of an Emergency, Natural Disaster, Terror, etc.
Will replacing antennas on RDU4100 increase range, if so what kind. (no repeater)
Can the RDV5100 be programmed to be used as a marine radio (campus on waterfront) would be used on tender. Not transmitting from land. And can it receive weather channels. Any other antenna to increase range if used for marine use.
Thank you,
Bill
