Motorola DTR 2450 and 2430 programming software
Hello everyone !
I am a proud owner of a pair of DTR Motorola radios, series 2450 and 2430, now no longer supported by Mot.
They are pretty much the same as the DTR 450, but operate on the 2.4Ghz band.
I am looking for the compatible Personal Computer Software for programming these, I have the cable data. The latest version available for free at the moment (V.3xx) is not working, says “the device not compatible.”
Many thanks for your help and support
-G.
I am assuming you are in Europe or the UK? These radios were not sold in the US or Canada, nor are they legal to use in North America.
If you are in the UK, it is unlikely the programming software for the North American DTR 410 is going to work because the 410/550/650 operates on the 900 MHZ band and the European DTR 2450 operates on the 2.4 GHZ band.
I can’t seem to find any links to the software either, so I would suggest you contact your dealer.
As for programming, what do you want the software to do? The software just makes it easy to program multiple radios and it allows you to create unique names and identifiers. It is NOT necessary to program any function. (All programming can be done through the keyboard, and if you want unique names and identifiers, they can be added using the accessory keyboard.)
