Since i am new to using two way radio’s, what is the best GMRS channel by experience to get maximum range?
I assume different frequencies/channels have different (although maybe minimal)ranges?
The radio still only has the same 22 FRS/GMRS frequencies as other similar radios. The “extra” channels are NOT extra frequencies at all. They are simply the same frequencies with certain codes predetermined for you.
Using that chart you can make ANY frs/gmrs radio talk to them.
Thanks Speedy. I fully understand “extra channel” setup. Just want to avoid FRS ( low power ) channels. Since list only has 42 channels i need channel list for remaining 8.
