Does the XS20G have a superhet receiver?
No. Direct conversion.
The KG-1000G is a superhet receiver.
Thanks! I appreciate the response.
Another question if you don’t mind…
Is there a qualitative difference between direct conversion and superhet? One better than another for GMRS?
Thanks!
A superhet has a lot better selectivity than a direct-conversion receiver. Digital signal processing has cleaned up direct conversion receivers a lot, making them fairly decent to use nowadays,
A superheterodyne receiver like the Wouxum KG-1000G transceiver I have is much better. Better selectivity and sensitivity. Cost more to make but needed in most situations.
