KG-UV9G Programming
Hi. First time poster noob here. Has anyone else had issues trying to program the Wouxun KG-UV9G? I had issues with the USB cable drive but I have that worked out. Now I am getting an error with the programming software:
“An unsupported operation was attempted”
Any help would be greatly appreciated.
Please make sure your cable is using Com1 and reboot your PC otherwise it will not work.
I’m having the same issue. I’ll give that a try in the morning. Thanks!
Try the 32-bit software instead. There’s a directory installation location error with the 64-bit installer app. :slight_smile:
you may need to run the 32 bit in compatibility mode Try win7 first. Make sur you run it as admin
I ran my windows 10 in compatibility mode windows 8 to program my 905G and it works great
