Have 2 of the new KG-UV8H, they work great except,
Noticed that when set for cross band repeat operation, the pass thru audio is very low and distorted. Tried both radios with the same result. Have a set of older KG-UV8D and no problems with either radio during cross band repeat operation. The H configured same as the D. It appears there is a problem with cross band repeater function in the newer H version that was working fine in the D version.
Anyone else having this issue ???
