KG-905G Scanning Bug
I just discovered a bug with the KG-905G radios.
Our team has a set of radios that are set up to scan only channels 4 and 5. Here’s the scenario: If I’m scanning those two channels and someone in our group transmits, the scanning stops as it should but if their transmission is longer than about four seconds, the signal will cut out for a quarter to half second every four seconds as the radio resumes scanning ever so briefly. We have menu item 16 [SC-REV] set to TO and it’s obviously tied to that setting but that should only take effect after the transmission has ended, not during it.
I also strongly suspect that this four-second scan affects how long I have to respond before my radio starts scanning again. So If the other person has a seven second transmission, I will only have one second to respond on the correct channel by pressing PTT before scanning starts up again. If I miss that window, I’ll be left guessing as to which channel they were on.
This seems like a significant bug to me which seriously degrades the scanning capability I was hoping to exploit. Yes, we could switch the SC-REV setting to SE but then every member of our group would have to remember to manually start scanning again after every series of communications, even the ones that didn’t involve them at all. I’m hoping the manufacturer is able and willing to fix this with a firmware update.
Hi. You need to set the “Scan Mode” to “CO”, which is “Carrier Operated”. “TO” is “Time Operated” and does exactly what you are describing. In “CO” mode, your radio holds on the received channel until the station you are listening to stops transmitting or gets out of range. I hope this helps.
Thanks. We ended up with the conclusion that scanning both channels caused more grief than it was worth, regardless of the SC-REV setting.
