Hi all,
I have a TK3860 which works great with the included KMC-35 mic, but I can’t get it to work with my car race harness. Specifically, the microphone doesn’t work. PTT and audio out work fine.
I have the service manual, and the pinout of the 8 pin ethernet jack on the front of the unit includes these wires:
MBL
SB (power from radio, not needed)
GND
PTT
ME (Microphone ground)
MIC
HOOK
DM
The car harness (PTT & mic portion) only connects to the PTT, ME, MIC wires, which seems like it should be fine, since PTT grounding to the ME terminal should work.
I created an ethernet fanout cable, and confirmed that I can’t get the mic to work even when i trigger PTT by connecting the PTT wire to the normal GND cable, and also confirmed that grounding the PTT to the ME cable will trigger transmit.
Is there something else the kenwood might require on the hook or DM wires maybe? Maybe something in the software to tell it what kind of mic I have? I haven’t logged into the radio to look deeper into the settings yet.
Thanks in advance for any advice!
