How do you determine the channel frequencies and pl tone codes a radio is set to? Specific radio would be a Kenwood TK-3200L (K3 ).
Here is a link to the operating manual for that radio. Pages 21-26 should tell you everything you need to know about getting your freq’s and PL tones.
http://www.buytwowayradios.com/Products/Kenwood/manuals/TK-2200L-3200L-manual.pdf
OK, so this is the low tech way of doing it, which while effective can be a pain especially if the radio is not set up for simplex operation (same frequency/tone to transmit and receive). Get someone with a scanner to narrow down the frequency to the channel selected on the Kenwood. Then from there a cheap Chinese walkie with PL tones can be used to narrow down the exact tone if there is one. The easiest way? Take it to a dealer, they will be able to tell you exactly what it’s programmed to.
