Hi.
Bought a cable from Baofeng for repeater use, and programmed with a +0.0600 offset (see attached pictures).
It works but it doesnt send before you talk or blow hard in the mic.
Not tested from a distance yet but some scratching.
Is there any settings on the radio i need to change?
Turn off VOX. MENU-4
You also do NOT have your programmed channels set up for repeater operation. The offset in VFO mode will NOT work for programmed channels.
go to miklor.com to read up on how to operate your radio.
Hi.
Only channel 4 is intended to be a repeater channel.
Se that it was a typing error there, should be 0.5000 offset.
VOX was off.
