Hi looking for free info.Former CB user looking for better hand held communication to another hand held or base. If CB hand held was available with SSB I prob wouldn’t be looking elsewhere. So short of buying and trying any advice? Not looking for magic. Just CB handheld leaves a lot to be desired. Oldbev
Many years ago I had a Realistic (Radio Shack) 5 watt handheld CB radio. It was a bulky thing with a 3 or 4 foot antenna! It worked fairly well but 27 megahertz just won’t cut it for a walkie-talkie type radio.
I now have A 50 watt GMRS base station and A 50 watt mobile. A FRS and especially a GMRS walkie-talkie is small and provides great coverage depending on terrain and structures.
CB is fine for base stations that have a fairly tall tower with a LARGE antenna. Not a good solution at all for walkie-talkies. GMRS DOES require an inexpensive FCC license, however.
Best wishes. Tom WRQE346
No test for GMRS license and $35 for ten years and is cheap for license fee.
Many GMRS HT’s have removable antennas, and one can get an adapter to tie them into a decent mobile antenna to increase the range considerably. You won’t be getting any “skip” , either. Check mygmrs.com to see if there are repeaters in your area. Those will increase the range of your HT(s) immensely.
Realize there are fewer channels than for CB. The channels are shared with FRS radios. I find a lot of unsupervised children on Channels 1-6 and 20. There are “flaggers”, some truckers, and some businesses using the GMRS. We have a pot shop, a dog day care, and a traffic flagger company using GMRS in my neighborhood.. The lady traffic flaggers were talking some topics one day that made me blush (and I’m 65). Some hot gossip about acquaintances.
I replaced the antenna on my GMRS HT (Wouxon KG-805) with a Nagoya NA-771G antenna to improve the signal. I am thinking of upgrading to a different HT soon.
I would check, before buying radios, if RTSystems or Chirp programming softwares are available for the radio you have in mind.
Good luck in whatever you decide…
Dave, KJ7WUZ/WRHW845
Thanx I sit high on a hill and have the ability to have antenna around 25 above ground. Have always been happy with cb performance to another base or mobile just to and from hand held leaves lot to be desired.Prob just have to jump in
Thanx prob going to try looking to find something simple and not worry about programming. Not a radio nerd no offense meant just to many irons in the fire. Prob start with base setup being a mobile,power supply,good antenna and a hand held and go from there.
No offense taken. It’s just that some of the Chinese handhelds can be cantankerous to program in repeater channels. I find it easier to use a software. Buy Two Way Radios is good at supplying rewritten manuals in GOOD English, though. They are a sight better than the original “Chengrish” manuals! LoL… SO good luck my friend and hope you find a solution that works for you and enjoy it as much as I do!
73, Sir
Dave KJ7WUZ/WRHW845
99.9% of GMRS walkie-talkies & base stations require NO programming whatsoever😀 They are ready to use right out of the box👍
The major exception are Baofeng radios. I’m currently fighting with a UV-32 and a DM-32UV programming. It’s one step forward and 2 steps backwards😂
MY 50 watt base stations work exceptionally well. LMR 400 coax is pricey but very important on any long base station runs, especially when receiving GMRS signals at these frequencies.
Best wishes! Tom WRQE346
I grew up with CB radio. I’m in western NC and after hurricane Helene hit us HARD, I/we started looking for alternative ways of communicating besides ham. GMRS.
I have a base, 40 watt Retevis RA-87, 30ft mast, Retevis base 6db antenna and punch out simplex across the county and hit all local and repeaters up to 74 miles away which allows me good 5x9 conversation at 120+/- miles.
GMRS is line of sight and antenna height and a quality antenna plays a big part of punching out. Comet antennas are about the best for base. But because of repeaters, if you can hit one that will greatly increase your range.
If you want to stay/start with a handheld, two of the models I have are the Retevis Ailunce HA1G “HAG1” and the BeoFeng UV-9G. Both are GMRS which includes the FRS. Both are advertised as “5watt” are fully programable manually or using Chirp and are IS67 waterproof.
They both function very well both simplex or through hitting repeaters. I have several mobile radios in some of my vehicles and these radios really get out well both on the base and mobile antennas using adapters.
All mentioned above are available on AMAZON. Check the prices and I suggest getting the most (antennas, extra batteries, POGRAMMING CABLE, ear pieces etc instead of just the radio/antenna. And buy a 2 pack. Nagoya has excellent HT antenna as well as ABBREE are also good.
Hope some of this helps. Good luck.
Steve, WSFK961
Thanx ,sooo many choices options.guess I will have to dive in
Hello Oldbev,
I guess it depends what your usage requirements are. If you are trying to communicate with people in your group, or family members, or other known parties, then I suppose GMRS could be a good choice. The handhelds get decent range, provided you can hit a repeater. That aside, don’t believe all the numbers people throw out.
If you are simply looking for a handheld walkie talkie to reach out to “anyone who can hear you in an emergency”, then I think you have to re-think the GMRS option. Last night I was speaking with an operator who has both a CB base station AND a GMRS radio. He got into GMR S thinking he would get better range and more conversation opportunities and was disappointed. The main problem he told me was that there simply aren’t that many people on GMRS frequency to talk to. It’s basically dead and I should note we are in New York City. If you peruse many of these radio forums that talk about GMRS, ham, and CB, many of the proponents of GMRS will tell you that there are many repeaters in New York City and plenty of opportunities to speak with people. I cannot speak to the issue of whether they’re are an abundance of repeaters here in New York City or not, but after speaking to the gentleman, I just mentioned, I have to conclude that even if there are many repeaters here it’s apparent that not many people are using them. So if you’re just seeking to make random contacts then perhaps you try a handheld CB that has FM capability. In an urban environment, they carry a little better. The President Randy handheld is a great unit. Good luck.
It also depends where you are located. There are areas of the US where the opposite is true. For instance, in my area near the North and South Carolina border, GMRS is quite active and we have a fairly large and growing community of GMRS operators. At almost any time of the day or evening, I can key up to one of the local repeaters on a GMRS handheld and get a response. I also hear a fair amount of chatter on simplex channels. Granted, some are FRS users, but it doesn’t really matter. The point is, the spectrum is being used.
On the flip side, I hear very little on CB in my area.
This doesn’t mean that CB is dead at all. It just means that the service isn’t used as much in my immediate location as it is in other parts of the country.
The situation in the UK is similar. While there are people using our version of GMRS/FRS - PMR446, for chatting with strangers and friends, it’s sparse - and in my coastal area, I often leave my analyser connected to a wide band antenna and come back after a few hours to see what activity there is. PMR446 reveals just a handful of the available channels active - and most of those are small businesses and one local school - they talk to themselves, never strangers. I’ve heard chatty stuff just a few times in the past year. Just nobody to talk to - and the businesses don’t respond to anybody bar their own people. Doing the same thing on CB frequencies has a tiny amount of traffic. Ham radio on VHF and UHF is centred on two repeaters, with an occasional chat simplex. Looking at the input to the Digital DMR repeater we also have locally, it is sporadic local users, probably just perking the repeater up from time to time. Businesses on our allocated systems are also in decline - less and less still active and running. Marine band is busy - very busy at weekends with leisure boaters, and solid midweek with the commercial shipping. It really does seem that as a hobby - chatting with strangers is just fading away.
Been the cb route trying something different. Mostly for communication with family 15 20 miles away Thanx
That’s interesting Rick because one of the best youtube channels I have found for radio topic information is run by a guy named Erik and is called FarPoint Farms (https://www.youtube.com/@FarpointFarms ). He has had all manner of radios and was a licensed Ham for many years. He finally let his Ham license expire because he said it was dead in his area in the mountains of North Carolina and he was too far away to hit a repeater. Instead he went back to a CB base station with SSB and says he has made many more contacts that way.
As for myself here in NYC, just last night I got stuck in Traffic going back home to manhattan on the Deegan Expy in the Bronx. I turned on my CB on Channel 19 and raised a trucker who told me what the problem was. I was able to sneak up the right shoulder to an exit nearby, get eyeballs on the accident and was able to advise the truckers the right lane was shutdown and that they should get over to the left. They thanked me and I headed home. If you tried to raise someone here in NYC on GMRS in the same situation, you wouldn’t get anyone.
I like my Cobra HH50WXST Handheld CB. With right antenna it has great range. The VHF and UHF does range 1 to 6 miles unless a repeater/Node is also used then just use my cellphone around world with cellphone.
The CB is standalone equipment with good range.
My HH50WXST with a ½ wave antenna is over 20 miles. Using a 50 inch my range is about 5 miles.
The sideband is costly and only few on sideband
HH50WXST Shown with 2.5 meter antenna mounts to tripod
On box the range under optimal conditions and maybe from great altitude
