I am new to two way radios and I am trying to understand the issues involved. I have found lots of valuable information in this forum, and I hope someone can resolve the conflicting data I found for the Midland GXT900.
As far as I know, the FCC ID for the Midland GXT900 is MMAGXT950 which has received a grant (Rule 95B) to operate in the frequency range from 462.5625 to 467.7125 (which spans Channel 1 through Channel 14) at a power output of 0.42 W (which is less than 0.5 W). According to this info everyone without a GMRS license would be allowed to use Channels 1 to 14. I got this info from this link:
suggesting they could be operated as both FRS and GMRS channels.
Which is right? Can channels 1-7 be operated as FRS channels in Low Power mode? If these channels are GMRS-Only channels why are they listed as “Shared” and why did Midland get a 95B grant for the whole frequency spectrum including channels 1-7?
I guess the question really is if the GXT900 in low power mode emits less than 0.5 W. I did not find any info regarding the emitted power in the different power modes for this unit.
The only thing I do know is that Midland requested and received a grant to operate Channels 1-14 with 0.42 W in FRS mode. Am I (and the sellers of this unit) legally on safe ground assuming that the GXT900 operates in Channel 1-7 with power set to “Low” in FRS mode even though the grant is conditional on the power restriction (which I cannot verify)?
No… you must set it to low, since “channel 1” is also a GMRS frequency, you have the option to select power… only 8-14 are low powr only as they are FRS only channels.
