Gm 15 pro to UV 5R
I’m very new to two way radio. I’ve had some UV 5 R’s for awhile but hardly use them. I recently got a pair of gm15 pros and I’m having trouble getting them to talk to each other
Any suggestions will be appreciated, assuming I understand them😊
M
Tell us what you have tried so far.
Check to make sure both radios are on the same channel and that there are no CTCSS or DCS tones set.
Make sure there is some distance between the radios. If they are too close the receiver section of the radio can be overloaded and not “hear”.
You could always set one of the UV5Rs to the same frequency the GM15 Pro is TX on and see if you can hear it.
If none of that works try performing a factory reset on both radios and start over.
