Hi Folks,
I have recently upgraded all of our companies CP200d radios to Digital. A majority of the time the voice transmissions sound far away, garbled or like they are underwater. Does anyone know what the issue might be? My supplier has not been much help
Thanks
We’d probably need to hear a recording. All the digital systems are lower audio fidelity than analogue. Most are pretty close but there is a learning curve to get 100% communications. A bit like hairband, where the narrow bandwidth, higher signal to noise and fast speech means it’s more tricky for beginners to listen to than say, Marine band. Some digital systems do sound very robotic, while others are more natural. Some are frankly horrible. Good quality DMR is perfectly workable once you get used to it. A recording would let us establish how bad and untypical it is? However - with digits, if speech is there, then there’s probably no fault, and the weird sound is just the system you bought’s normal sound.
I have a similar problem. I have a tyt md380 that worked fine on DMR on a hot spot.
Tried to do it with a repeater and the voice is all garbled. On my 578 Anytone the DMR is fine,
Any ideas?
