Frequency Help?!
No one but your radio shop can tell you what frequencies are in your radio.
Posting the same message over and over is silly. So is posting in all caps.
If your radio has frequency 123.456 in channel one, that tells you NOTHING about what (if anything at all) is in channel 2.
It has whatever was programmed into it in each channel. In whatever order the radio programmer chose.
Just by the way, 153.485 shows in FCC license listings as being licensed to Water & Gas Dept., PITTSYLVANIA, DANVILLE, VA.
That frequency is allocated for use of Water and Gas Utilities. Not correctional facilities. Just might not be legally licensed…
Radioreference does show it (and nothing else) for that correctional center, though. Odd.
http://www.radioreference.com/apps/db/?ctid=2925
