Just purchased a pair of these from China. Does anyone else have experience with these particular radios? Just looking for some feedback on them. Here’s the specs on them.
FDC 268-B
General
Frequency Band: VHF
Frequency Range: 136-174MHz
Channel Capacity: 99
Operating Voltage: 7.2V DC ±15%
Antenna Impedance: 50Ω
Channel Spacing: 12.5KHz/25KHz
Working Temperature: -30 ℃ - +60 ℃
Frequency Stability: ±2.5 ppm
Size (Without Antenna): 50mm(W)x98mm(L)x30mm(D)
Weight(With Battery): 198g
Battery: 1200 mAh(Li-ion)
Compatible With American Military Standard(MIL-STD-810C/D/E)
Transmitter
RF Power Output: 4W/5W
Modulation Type: F3E
Modulation Distortion: < 5%(300-3000Hz)
Max Freq Deviation: < 5KHz(1000KHz When 100%)
FM Noise: <=-45dB
Receiver
Sensitivity(12Db SINAD): 0.16μV
Selectivity: 55dB
Adjacent Channel Selecivity: >=70dB
Noise Respond: >=60dB
FM Noise: 45dB/40dB
Modulation Type: 16KOF3E
Audio Power Outpu:t 500mW When Distortion Less Than 10%
Audio Distortion: < 5%
Operating Bandwidth: ±7KHz
Standby Current: < 10mA
Not legal in the USA, unless they have an FCC ID. They cannot be used.
They are VHF radios which could be used for MURS…but they aren’t type accepted, so illegal there. If they had the Part 15 approval, which they don’t, then they could be used for 2 meter amateur use.
They have no type acceptance for any service in the USA.
Perhaps an expensive paperweight or doorstop… that is it.
Requests for approval are submitted by the manufacturer. All radios must comply with governement standards and are done by a whole model series, not individually.
Radios can be seized by customs with no refund to you.
