What is the name of the Firmware file you are using?
If it is like this - 1702_v02.02.019, then I’m afraid you cant use that file.
As far as I am aware there isn’t an update for Firmware L05.01.004.
No problem.
There are 2 versions of this radio, even though the radio looks the same, the internal programming is completely different.
Version 1 uses L05.01.004 firmware and you need RT72 programming software.
Version 2 uses v02.02.014 firmware you need the MD CPS software.
Very confusing for new users.
Ok, very odd behaviour. Are you sure its switching off and not the screensaver cutting in after no use, (you’d be surprised how often this happens). You could possibly reprogram with a blank codeplug file. I believe there is one with the CPS software.
Hello my radio has a new radio problem it does not open to configure via PC wiht Micro USB and Rib 2 pins, watch the video of the problem, Baofeng DM-1702 GPS. Baofeng DM-1702 GPS Ver Firmware L05.01.005 Radio does not open on CPS: MD-1702 V1.00.78 , V1.00.66 and OpenGD77 CPS. video in youtube (Baofeng DM-1702 GPS problem configuration) Channel Bn SchL
