The problem with what you ask is the fact that the UHF does not have much range once you go inside the house, regardless of the power, due to some building materials being opaque to radio waves.
I went through this dilemma when the US went through the DTV transition and people could not understand the migration of the VHF stations to UHF and they could not comprehend that shorter wavelengths acts different from longer ones.
Your goal would be to have a decent transceiver that can be used economically that will stay in contact with others.
Another problem is you have to buy a license to do what you want to do!
The Family Radio Service only allows you to use one half of one watt of power…
Couple that into 50’ of coax and the signal would barely dribble out the end of the coax.
The Amateur radio type equipment won’t even reduce to that amount of wattage - 5 watts being the minimum amount of power they usually transmit with from a mobile.’
Once you detach the radio from the antenna, and move the antenna above the roof of the house you create gain.
Height gain to be more exact.
The height gain can overcome the lack of power - watts and even a couple of milliwatts can be heard several miles away.
The way the manufacturers circumvented the law was by making the device small and portable and limiting the size of the non removable antenna and the height, since you aren’t going to climb a tree or a tower to talk to someone.
Radios that are advertised for “FRS /GMRS only” are very expensive and they do not perform all that well.
The government must have outlawed them, or the manufacturers quit making them when they could not compete against a $40 walkietalkie…
You can buy professional grade equipment for about the same amount of money.
Since you are an individual, you aren’t going to try to use it as a hobby - (call CQ and talk to others that are not in your neighborhood), that it is overkill for what you want to use it for…
The professional grade equipment is very expensive, and not a simple solution.
The license alone is $85 for 5 years…
You would need a radio, a power supply, a ground network for the antenna system, a piece of low loss coax to go from the radio to the Polyphaser to the antenna. Some sort of mast to hold the antenna in the air and the antenna itself.
When asked for a quote, people cringes and they refuse to pay!
Radio - $250.00
Power Supply - $150.00
Ground - $100.00 installed
LMR 400 - 50’ - $100 with connectors.
Polyphaser - used to keep the lightning out of the house $50.00
Antenna - $125.00
Mast - $100.00 installed
You can reduce the cost slightly by using mini8 ( $.69 a foot) instead of LMR 400, but the other costs are pretty much firm…
Most people do not realize that regardless of if it is just a couple of watts or a hundred watts / that it still costs basically the same amount of money.
