Greetings all. I’m new to the site. MANY years ago I had been into scanners and recently bought a Baofeng UV(BF) 21R and the Tidradio TD-BL-1 wireless programmer. First off, this scanner is SO confusing. I tried using the OdMaster software to install the dongle but I keep getting an error message that there is a bluetooth connection error. My phone bluetooth and PC are working fine. What is the issue and what do I check to fix the connection error? Keep in mind, I am so lost with this radio and the writing in the manual is so tiny it’s hard to figure out. You’ll be seeing A LOT of me on here as I work through the settings. As of now, all I can get is weather radio.
Just to clarify. You should not use your phone’s Bluetooth setting to search for the programmer. Use the Bluetooth option in Odmaster itself.
After that, its just a matter of selecting the correct radio from the list on Odmaster.
I have experienced that if you wait too long, it sometimes disconnect.
