Baofeng GRMS Radio can't transmit to FRS Radio on channel 6 privacy mode 11
Hello
I am new to GMRS. I just bought a pair of Baofeng GM-15Pro. I performed a reset before setting up the Baofeng to channel 6 and privacy mode 11 (6/11). I tested it against a regular FRS radio and the Baofeng can receive clearly anything sent from the FRS radio. However, when I try to send from the Baofeng, the indicator light shows that it is transmitting but the FRS radio doesn’t receive anything.
Any help would be greatly appreciated. Thanks
I finally figured this out and posting this just in case it may help someone else.
I had to set the channel 6/privacy mode 11 as well setting TX CTSS and RX CTSS to the appropriate values and keeping DCS to OFF. Below are the values for Privacy Code 11 - 17
Privacy 11 = 97.4 Hz
Privacy 12 = 100 Hz
Privacy 13 - 103.5 Hz
Privacy 14 = 107.2 Hz
Privacy 15 = 110.9 Hz
Privacy 16 = 114.8 Hz
Privacy 17 = 118.8 Hz
Welcome to the forum!
I am personally not familiar with that Baofeng model, but from your list, those are presets for select CTCSS tones. This is not uncommon for some bubble pack FRS radios, but those presets will be different for each brand, and sometimes each individual model. The user manuals usually include a chart that lists the privacy or PL tone assignments and the specific tones to which they are assigned, so that you can cross reference and match them with the tone assignments of the other makes and models. It’s always been a point of confusion, particularly for those who are new to radios.
Fortunately, most programmable radios today simply list the tones and codes themselves in the radio menu or the programming software, which does require you to know what the specific tones are and set them for the channel you are using. However it’s a lot less confusing than trying to match PL tone 11 on one radio to PL tone 11 to another radio, which may or may not be assigned the same tone or code.
Hi Rick
Thanks for the welcome message. Yes it was a lot for a newbie to GMRS radio. It took me a while to understand how this all works (also thanks to this article FRS/GMRS Privacy Codes Demystified ) . Then once I got the feel for it, the manual that came with the radio also had conflicting CTSS code listed. But I got it all sorted out for now.
