baofeng disable or block side key moni(monitor) for don?t listen private cts dts
please help me, i need disable or block side key moni(monitor) for don?t listen private cts dts. baofeng uv-5r,uv-82
Sorry - I don’t quite understand what you mean?
David, the side keys on the Baofeng UV-5R and UV-82 are not programmable and their functions cannot be altered or disabled.
When you are in frequency mode and want to transmit on the frequency you are on, only other Baofeng radios or Frequency scanners on the same frequency will be able to hear you. I you save this frequency with the right CTCSS you will be able to communicate, otherwise not. Or if you program your radio on the computer using the programming cable you can set your duplex to off and then you will never be able to transmit.
I hope you get it right.
