Antena connector types
Hello everyone and thanks for the invite, trying to help my girl with listening atc coms as she’s getting her pilot license, i’ve got here a hand held radio (basic one) Abbree, and a flexible antena, my issue now is that the radio and antena have different connectors, i’ll attach some photos,
if someone could tell me what addapter should i get it will be amazing, thanks a lot in advance
The threaded stud type is quite common, but isn’t really a connector, just a screw insert. Using adaptors frequently makes them a different length, spoiling the match. It’s simpler just to buy a new antenna (from the forum hosts 2-way radios, for example) The new antenna needs to be an airband one with an female on the base.
Good idea about gaining experience by listening to ATC.
I am not sure what aftermarket antenna you wish to attach, but few of them give much better performance than the antenna it comes with. Longer ones might give you slightly better range, but at the cost of less mobility. An external antenna with a magnet mount can often give a bit more range if the radio is inside the vehicle, but quite frankly, if you are hoping for substantially better performance with another antenna, you may be disappointed.
Listen to my friend Paul’s advice about not getting adapters; get the proper connector.
By the way, that radio is a ham transceiver that happens to receive airband, but they are not really optimized for airband reception. It is more money but you should consider a scanner. It will give you better reception and much better scanning speed. For example, the Uniden BC125AT is highly regarded for airband reception.
Another thing to consider if she gets serious (and we hope she does) about flight training is that you can get an aviation transceiver. This will not only give her the ability to listen to airband on a dedicated radio, but it can also act as a backup radio when she starts doing more advanced training.
It’s again more money, but our forum hosts at buytwowayradios have a great selection of airband transceivers. I actually sold my Icom scanner and bought the Wouxun KG-S74A transceiver from them, and I love it.
We have a chart of common two way radio connector types with photos of the connectors that may help.
I’ve got some brand new Icoms, Yaesus and older Icoms in all kinds of models, and they all perform so much better than those Abbrees - the real difference is the reduction in noise, and sensitivity. My local airfield who do parachuting is an example. On the proper air band radios - one on my desk hears the controller, the Abbree struggles with the drop aircraft at lower levels.
