I found this Vee Dipole antenna on internet. How well does it work over a well ground monopole antenna.
If ever wonder the history of Dipole it invented by a German for radios on Zeppelin. It call a Zeppelin till 1930’s rename Dipole
They were (are) a bit of a fad. The science works though, changing the radiation pattern in a usually good way. Years ago I used to be into downloading satellite images, and a vertical dipole was a problem, because the radiation pattern is a bit like a donut, so a satellite above you was weak. a they came towards you signal strength went up, then as you got more vertical, it dipped to almost nothing overhead, then it would come back. If you move the dipole elements away from vertical, the no signal overhead was much better. It was, of course a little weird towards the horizon, and viewed from above was not circular. HF folk with a very high mast can use the same tweaking to allow the dipole to head downwards - with the same changes to the polar pattern. As a horizontal dipole is already directional, the skew added might be good or bad. My experiments were with 137MHz and down in the 10m band and down there, angles were really dependent on practical stuff like where you could attach to. The one in your pic is just a rigid one for 10/11m I guess? Performance will be variable - lots of rotating and messing around. A vertical gives consistent 360 coverage, that one is directional to some degree. I think the matching was pretty close to 50 Ohms with V type designs - but I am not sure?
It very hard to get good data.
The data on a dipole is +2 db
Then on monopole is same db it does say depending on ground
Then I wonder which one better with good ground.
I can see a dipole on aircraft or tv is a good thing
No - The data is dependent on orientation and direction, plus of course polarisation. With a dipole, ground is not usually part of the design - centre feedpoint, in free space. proximity to ground will alter everything. Treat it like a conventional dipole with two identical length elements, fed centrally. Impedance changes so if you adjust the angle, you might even get a good match to 50Ohms so non balun required. However, changing a dipole’s angle from the conventional 180 degrees does peculiar things to the radiation pattern that might work for you or against you.
The thing is to compare apples with apples. An aircraft is a shape with constraints. Some old designs would have an insulated stub at the front, a feed point centrally and the other connection on the tail - this produces a V shape, changing the dipole performance. Other aircraft constraints would make the antenns more a long wire, possibly using the aircraft airframe as the counterpoise to the long wire (which of course is a short one for HF) - an ATU would be needed to make it match properly. Treat them as 0dB because while you may get a little gain in one direction, you will lose it in another. They are compromise designs.
About the only place I see rabbit ears is on portable antennas.
It like having two antennas doing same job as a good monopole with good ground. I know it like in aircraft because no ground is need.
