Tone scan problem
Continuing the discussion from New Wouxun KG-XS30G Mobile GMRS Radio:
Having problem with the tone scan o. This radio followed the manual to the t and still not can’t get it to work. I have one radio set with dcs tone and transmit with the KG xs30g in tone scan mode and will not scan I have radio cord to plug in to pc and played around with settings on the pc and send to the radio. Did not work been playing around for hours trying to get the tone scan to work anybody else having problem with this setting?
Welcome to the forum!
The Tone Scan only performs the scan while a signal is being received. As soon as the other party transmits, you need to go into the menu and choose Tone Scan and whether it’s a CTCSS tone or DCS code to start the scan. It won’t scan unless there is an active, incoming transmission, and only while that transmission is being received. As soon as the transmission ends, the Tone Scan will stop, whether a tone or code is detected or not.
If it doesn’t work as described, give us a call or email our tech department and they can assist in troubleshooting the issue.
