Hi all,
I have a eurotel model 0639.
I have a Midland Xtra Talk GXT800
Please can someone tell me how I can use these two together??? I really need to know by tomorrow if possible, thanks!
Hi all,
Depends on which market they are programmed for. If both are on the same system (like PMR446 in the UK) then channels and CTCSS tones are the same - so they should function. The channels may be a bit mixed up, but most should work. If you have them from different sources, then you could have one on the US free channels and one on the UK version - and that would not work. If you are buying from one country, the chances are they are on the same programming. 100% certainty is a bit different?
