Hi All, As you have see on TV or maybe experienced, hurricane Ian pummeled SW Florida and then proceeded to keep on the move to other areas.
My house is about 15 miles from where Ian made landfall bringing 155+mph winds, rain and storm surge. Fortunately our house was spared much in the way of damage due to it being a new build and up to the latest building codes.
Since this storm was about 400+ miles wide, it left a huge path of destruction in it’s wake.
A few things to think about for your emergency prep in the way of communication. Here’s what happened. Power goes down. Internet goes out because of power. Cell/mobile service goes down because of power , Internet links and tower destruction. The local repeaters went down because of power and wind damage. Back up power fails because of 190 mph wind gusts.
Battery back up systems run down and everything stops.
So, after the storm clears, crews frantically try to get enough repairs made to get the repeaters up.
One made it, running on a generator. Echolink is impossible because of Internet infrastructure damage. Generators need fuel. Power is down so fuel can’t be pumped. You can’t drive down the street to get more because power is out for a hundred miles and the road is full of downed trees and power lines.
At this point, your HT isn’t going to get out very far.
This is not a hypothetical situation. This is what happened.
In SW Florida, the water and sewer systems rely on electricity so those are down too.
So, what to do. No outside antennas survived. Attic antennas did for those that kept their roofs.
A push up pole for an antenna is a great item to have in order to get some distance out of that HT or other 2m/70cm radio. Simplex communication was very important in getting emergency services to areas that needed them.
Power, generators are great but do require fuel and to be refueled and refueled.
Portable solar panels and a solar generator does a very good job of keeping batteries recharged and minor systems operating for extended periods. The larger ones can even run the fridge too. FYI, solar panels on the roof tend to go flying in winds like we had.
We where kind of at the end of the line for power restoration in our area. 10 days. Once power was restored, life returned to somewhat normal conditions for us. They’ve even lifted the boil water notice.
I just thought I would share a little insight with anyone that is thinking of back up systems and prepping for whatever may come your way. Any and all infrastructure will fail at some time. Hopefully not as complete and wide spread as this time but it does happen.
As hurricanes are nothing new to me, I’ve collected things that I needed over the years. The outages where a bit extended this time due to the size and power of the storm but I’ve also had these length of power outages due to winter storms in the Appalachian mountains. It can happen anywhere.
WO4KAC Kelly, Port Charlotte, Florida
