Menu on Baofeng
I am really radio stupid. Heres my situation. I run security at Jellstone in Indiana. I can hear just fine but getting out to others seems to be an issues. I need someone to run me through all menu setting and tell me what should be selected… Can anyone help please…:frowning:
It’s not that simple. We need more information.
First, what specific model Baofeng are you using?
What frequency are you using?
What are the make(s) and model(s) of the other radios you are receiving?
Where are the other radios located?
where is your radio located?
How far apart are all these radios, including yours?
Are you attempting to transmit from indoors, outdoors, or a mix of both?
Are you using the stock antenna on the Baofeng or is it an add-on?
Are you or any of the other radios using any tones or CTCSS/DCS codes?
If it is a dual band Baofeng, are you transmitting on the same side and band from which you are receiving?
Is your battery fully charged when transmitting?
Check out U-tube!
www.miklor.com
