Is the brts30k11224 will cause any interference to another nearby base stations
hello all
can some help me please
the brts30k11224 datasheet
model is band selective but not channel selective. We are not sure if this type will cause any interference to another nearby base stations.
I have no idea what that device is, as google nor the link seem to to work.
If you have a receiver that operates close to the frequency of a nearby transmitter, you will, if the two antennas are close, discover the receive sensitivity drops - as the transmitter desensitises the receiver. The amount is a combination of proximity, and the difference in frequencies. It can be reduced by using tuned filters. If the spacing is, for example a few MHz, and the distance a few metres, then the desense (with a decent design) can be insignificant. Try the same on a poorly design radio with little filtering and just a few Watts can make the receiver totally deaf. We need more info.
Another CCR possibly? Due to poor quality control on many of those units you can experience unexpected operation of both the transceiver itself and other equipment. I wouldn’t be surprised to hear about garage doors opening and closing when you press the PTT or your neighbors pacemaker malfunctioning.
