To be honest, no. We have slapped ferrite cores on practically everything, and the magic CE marking, which frankly means nothing at all, is usually just a label, applied at will by the manufacturers.
The HF bands are so full of crud nowadays that many people with less than wonderful antennas really struggle. The other day I was programming some radios with low band VHF channels - the 70MHz amateur allocation, plus for one customer, a frequency in the 80MHz band used here for race/rally communications. I programmed the radio and to check it, I dialled it up on my scanner in the office which usually monitors VHF marine band. Full scale on the meter, not just on the rally channel, but across the entire band. I’d never noticed. I stuck an extendable whip into the analyser and what a mess the 70 and 80MHz band is. I’ve got one of those RF explorers, so I stuck in the rally frequency centre band and wandered around. The wall-wart power supplies are the main culprit but my internet hub is crazily noisy, as are two computers out of the 7 in the office. The best ones are in metal 19" rack cases, and the worst is a plastic case Dell. I have a Ring alarm, and that’s definitely a source of noise, but not too bad. Two DECT wireless phones are also quite noisy. All these items have the CE marking on them. The scanner is connected to an outside marine band antenna, and with that connected to the analyser, the band starts to get noisy around 87MHz and then as the frequency drops noise rises worryingly. I’ve not noticed this before. I pulled out my marine Icom HF rig - like the ham ones but receive and transmit everywhere, and connected to the only antenna available that has any HF performance, 2182KHz is S9 noise, and this repeated through the HF bands.
What a mess! I’m glad I don’t use the HF bands - finding’s anything louder than the noise is very hard. It does seem our two countries have let this creep up, and are now powerless to do anything.
