bus two way used for company business?
My company uses the two way radio for business, such as work schedule fill in request of drivers. Also when they need to call a driver into the office.
This seems outside the scope of two way radio communications. Is this common? Is this allowed under the rules of the fcc? Any comments?
Thanks!!:confused
Radio systems fall into three categories - leisure, amateur and commercial. The license type you select allows you to do different things. If your firm have an appropriate license, your use is typical. If you are using one of the free, no frills hand held systems designed for leisure use, all I can say is that here in the UK, that is allowed, but annoying because people rather enjoy messing about with it, making it less than reliable.
