Hello does anyone know how to enable vox on s Baofeng T18 two way radio without using the programming software? Is there a way to enable vox just on the radio itself?
If they have a PDF manual on your radio . You use search on the PDF app to find VOX .
I have Cobra S19 FM it dose part by programing for time and sensitivity
Then Enable/Disable VOX
- Push and hold the Push-To-Talk switch on the microphone, then
- Push and release the MENU button.
- This will both enable and disable the VOX function.
I do not know your radio but gives a idea how may work. I do not use my vox i like a good old microphone.
They don’t have a pdf manual. There isn’t a menu button on the radio. I want to use the vox with the ear piece while hunting. Otherwise PTT makes to much noise
I did some poking around and this is what I found:
- Turn off the radio
- Rotate the channel knob to select any channel between channel 1 and channel 5.
- Press and hold the PTT button and the MONI button simultaneously.
- While holding those buttons down turn on the radio.
- You should hear a voice prompt confirming “VOX On”. VOX is now activated across all 16 channels
- To tune VOX OFF use the exact same steps.
I don’t own the T18 so I can’t varify all of this.
Thanks that suggestion worked
