Antenna Lub for telescoping tpye
Duo Error in posting
Ideally it should be conductive - so copper grease works - but the fingers inside that make the contact do NOT need grease of ANY kind. They are designed as a greaseless sliding joint because chrome does not need any sliding assistance at all. Grease that insulates is bad. The killer is corrosion under the chrome. Whoever told you car wax, chapstick and floor wax is an idiot. WD40 is good for removing whatever is gumming things up, but the light coat of oil residue attracts dust of course so the cycle starts again. I have had so many telescopic failures over the years but they are caused in the main by deformation and corrosion - with binding being usually deformation induced. Corrosion damage is rarer since chroming technology has improved and base metals better forumated.
wind instrument cork grease I heard being talked about once. I’m a sax player, so tried it. Horrible, just like using vaseline. Sticky and a great insulator - just what you don’t want. Need proof? Stick your test meter probes into whatever you intend using. If it’s not a short, then it’s an insulator, and insulation between sections is always a bad thing.
From my days in rc models in 1960’s
I am not disagreeing with you.
I have a lot on telescoping antenna cleaning and lubrication.
Most say us WD40 for cleaning and lubrication powdered graphite.
But threading aluminum to aluminum it can weld/seize together without a anti seize component made of copper. This also happens with stainless to stainless or titanium to titanium.
But as long as you are threading to brass no problem
David, this has to be your best post yet!
I could actually understand what you’re saying.
The first ones was nickel plating later chrome plated brass tubing with brass bushings.
Today I see stainless steel with I think is brass or even on low cost aaluminum maybe brass
