Go Back   Two Way Radio Forum > Two Way Radios > Amateur Radio
Old 05-13-2019, 07:28 AM
DuckyTehGreat DuckyTehGreat is offline
Default Motorola XTNiD help required
Hi there,
I have a pair of Motorola XTNiD radio's that I was gifted by a friend. They work amazingly with each other, unfortunately, I cannot get them to work with any one else's radios. When on the same channel as anyone else I cannot hear anyone nor can they hear me on either of the two XTNiD, though the two XTNiD's can hear each other.
I'm hoping someone on the forums knows what I might need to do, I've looked into the manual - link below - but can't figure out what might be causing it. An RX code was set to 121 for several of the channels but I set this back to 0 - it affects all channels anyway - and I have ensured scramble is set off.
Am I doing something wrong?
https://www.motorolasolutions.com/co..._manual_en.pdf
Old 05-13-2019, 04:36 PM
Default Re: Motorola XTNiD help required
Quote:
Originally Posted by DuckyTehGreat View Post
Hi there,
Well, your radios are programmed on different frequencies than the radios you are trying to talk to. Your radios are programmed for a specific set of frequencies and the radios you want to talk to are likely programmed differently.
Licensed ham: KD8DVR
Licensed GMRS:WQWK521
Disclaimer: All posts are personal opinion only and may not state fact or accusation.
Old 05-13-2019, 04:38 PM
Almost certainly a mismatch of the CTCSS or DPL codes. Probably more likely to be that the other radios just don't match. What will really help is a programmable radio that will operate on all the combinations, simply and be able to identify what exactly you are sending, and what will open the squelch on receive.
Old 05-16-2019, 08:14 AM
Thank you both,
Is there a way to find out what frequencies they are likely using?
The radios used by my teammates are extremely cheap models (around ?30 a set).
Thanks again
Old 05-21-2019, 09:52 AM
Rick S Rick S is offline
Administrator
One possibility is to use a scanner or frequency finder to detect and identify the frequencies transmitted by the radios.
Old 05-21-2019, 04:36 PM
K6CPO K6CPO is offline
Member
Hi there,
You radios are PMR, which I think is the UK version of GMRS. What radio service are your friend's radios? If they are in a different radio service, then the frequencies aren't going to match.
